vcEvent
vcEvent provides a way to register event handlers for different events. Event becomes invalid when the source of events is deleted. Accessing properties or methods of this event will raise a ValueError telling that event has been invalidated. It is possible to use "IsValid" property to check the state, without raising an exception.
IsValidBooleanRGets a value that defines if the object contained in this event is still valid.
resetNoneNoneRemoves all registered event handlers.
waitobjectOptional Keyword[filter = Callable]Blocks script execution until an event has been triggered.
Optional: filter (function): User-defined function that evaluates event arguments and returns True whenever the script can continue its execution.
Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. When "filter" is specified, only arguments that pass the filter are returned.
